Wire for aux lights into cab
Old Jul 21, 2015 | 04:23 PM
dukie748's Avatar
Default Wire for aux lights into cab
Where is the best / easiest place to run a wire for auxiliary lights - from the engine bay through the bulkhead and into the cabin? Thanks in advance.
Old Jul 22, 2015 | 07:45 AM
Old Jul 22, 2015 | 10:59 AM
dukie748's Avatar
Thanks for your lofty wisdom, I tried searching using various terms to no avail.
Old Jul 22, 2015 | 11:09 AM
rsc's Avatar
rsc
Under the dash behind the steering column is a factory pass-through for the wiring harness from the engine compartment. The H3 has a double firewall so there are also two grommets there. You could also drill your own hole and install a grommet where ever you wanted. I think that there are one or two other pass-throughs as well.
Old Jul 26, 2015 | 10:02 PM
happythree's Avatar
look where the clutch pedal would be and find a hole in one layer of the two layers. its a good place to drill a 3/4- 1 inch hole with a unibit or hole punch as i did. run wire thru a grommet or rubber hose and fill voids with putty.
youll be ready for the NEXT wires!
Brent Whitfield
Feb 12, 2014 06:40 PM
Truckie
39
Feb 24, 2013 02:51 PM
sfgiantsfan9
Oct 4, 2010 06:33 PM
jasontag
Apr 26, 2010 10:08 AM
mountainbiker
Feb 6, 2007 05:44 AM
