No spark and no fault codes
Old Dec 3, 2023 | 07:59 PM
Babajaga's Avatar
Default No spark and no fault codes
I’ve done all the standard tests and resets but to no avail. Oddly passlock light is acting as it should, there is no error code yet I have no spark.
i am going to switch out the ign switch module. As the starter has been hanging up and I think it’s in the switch. Any ideas?
Old Dec 4, 2023 | 09:27 PM
legerwn's Avatar
check for 12 volts at the coil harness, each coil should have voltage with the key in the on position and engine off
If no voltage look for an ignition fuse issue under hood fuse box,
If possible get a scanner and look at the theftlock status and make sure its enactive
Neal
Old Dec 5, 2023 | 01:38 PM
gearheadib's Avatar
You could check the VATS system. turn it off and try to start it.
Old Dec 5, 2023 | 11:42 PM
Babajaga's Avatar
Thanks for all the insight. And sorry for the duplicate thread. I’m going to try out a crank sensor. I talked to a hummer tech, he told me the theft lock system disables the fuel so it’s not in the equation here. It would not disable the ignition.
Babajaga
Dec 5, 2023 11:41 PM
smokewatts
Mar 9, 2018 07:37 AM
johnnyreno
Nov 11, 2015 01:40 AM
jamesb1516
May 4, 2014 08:36 PM
gotafish
Mar 22, 2012 04:10 PM
