Need A Pin For The Rear Hatch Handle
Old Mar 31, 2024 | 03:13 PM
peeplwtchr's Avatar
Default Need A Pin For The Rear Hatch Handle
Hi All-
Can anyone please tell me where to order the pin which secures the handle to the unlock mechanism. I'd rather not buy the whole handle kit.
It's the pin which goes through the handle, and the hole which is pictured with a zip tie stuck in it. Also the pins in the full latch kit screenshot which is attached.
Thanks!
Old Mar 31, 2024 | 03:19 PM
if you still have the pin you can just get the C clips. it might still be inside the door if it fell off. or just get a long enough bolt with a nylock nut.
Old Mar 31, 2024 | 03:59 PM
finall's Avatar
Further to what Bronxtech said, U can use a thinner bolt with a steel sleeve (readily available) to avoid the threads chewing plastic. Washers at both ends.
HandsomeSteve
Jan 22, 2024 10:39 AM
pizzaguy
Jan 18, 2022 02:38 AM
Rogcapital
Dec 10, 2021 11:07 AM
calif phil
Nov 25, 2015 03:45 PM
Dylan22
Apr 27, 2012 05:11 AM
