Lets see you dual battery setups!
Old Mar 22, 2026 | 08:15 PM
XLRH2's Avatar
Default Lets see you dual battery setups!
I ended up buying a new battery, thought the old one was toast.
So figure why not add the old battery!
Both stock size batteries.
Thinking adding the second battery to cargo area (rear mount spare).
Thoughts on placement?
Share your setup please!
How would I wire it up?
Thinking just add ground to any good ground point in cargo area and run a positive cable to engine bay.
Connect directly to front battery pos+ terminal?
4 gauge? thinking similar to adding an amp?
Fuse connection?
Alternatively considered tossing stock intake and making custom intake and add pass side battery tray?
Seems like a lot of work just to mount an extra battery, lol
Or any ideas what to do with a massive 12 batt? lol
unrelated projects?
Old Mar 23, 2026 | 10:53 AM
put the battery on a hand truck add some booster cables and use it as a mobile booster pack
Old Apr 1, 2026 | 07:07 PM
Gavin Costigan's Avatar
I’ve been trying to figure this one out. I actually relocated my washer reservoir, put an Escalade coolant reservoir where that was and planned on mounting it up front. I would have to cut the inner fender though to make it fit. My adhd gave up on it for now but I’ll come back to it eventually.
when predator does the duramax they relocate the intake and put the battery there. I think they use a shorter battery tho.
Knowhum?
Jun 18, 2023 11:51 PM
oceanbrave
Hummer H2 SUT
36
Oct 3, 2022 03:15 PM
curleymon
Jan 19, 2019 10:49 AM
Tech5
Mar 17, 2011 10:32 AM
kdec19
21
Nov 3, 2008 10:10 AM
