Hummer won't start.... AGAIN
Old May 7, 2020 | 10:30 AM
  #31
Originally Posted by jwmingus
Apologies,, I am chasing two issues.. A DRAIN hose, and a Parasitic Drain on the Battery.
I have not identified (though testing) the actual drain on the battery. We are chasing that and unplugging systems..
I tried using a meter to detect the drain and had no success as it is random.
Patience during testing.. Other ways to test:
Old May 8, 2020 | 07:47 AM
  #32
jwmingus's Avatar
Again the truck is dead... Pulled OnStar, Radio, and Heater fan and the heater fan Resistor...
Dead Again,.. what next.
Old May 8, 2020 | 03:39 PM
  #33
i remember on older GM vehicles the alternator would get stuck and pull current. maybe try checking the alternator for a parasitic draw. another thing on gm trucks that can cause a draw is the instrument cluster not going to sleep after a set amount of time like it is supposed to. i personally had an issue with a bad XM satellite radio factory GM module going bad and causing a drain.
Old May 9, 2020 | 08:19 AM
  #34
calif phil's Avatar
I had an intermittent drain on my 03 and it was the electrical portion of the ignition switch, it would act as if the key was not all the way off and drain the battery overnight.
Old May 9, 2020 | 11:23 AM
  #35
jwmingus's Avatar
Thanks, decided to give in and taking it to a specialist to see if he can save it.... lol
Old May 9, 2020 | 03:46 PM
  #36
Don't throw in the towel yet and waste money. Battery discharges
Old May 9, 2020 | 04:59 PM
  #37
hummer_on_fumes's Avatar
I took mine to a mechanic and all they did was hook up a multimeter to the battery and pull the fuses until they figured out what made the constant draw go away. That's what you need to do to figure it out, either by using another multimeter to test the fuses or by pulling the fuses 1 by 1. The reason I didn't figure it out myself is because the blower motor was a big fuse that couldn't be checked with a multimeter. I didn't want to just pull the fuses but that's what my mechanic was doing. Also sometimes you have to wait a few minutes after each fuse is pulled because it can wake up other computers or do something to trigger the voltage
Old May 9, 2020 | 05:20 PM
  #38
I've seen that fear of pulling fuses all over the internet. Just think about it, same when you disconnect/replace your battery. Still the easy way to find.
Humm3r
Apr 5, 2021 01:21 PM
hummer_on_fumes
Dec 7, 2019 08:21 AM
hummer_on_fumes
Oct 11, 2019 11:39 AM
OregonMate
Hummer H1
Aug 9, 2019 11:21 PM
Big_A
Aug 15, 2015 01:20 AM
