Gm Top Engine Cleaned how to use?
Old Aug 25, 2024 | 04:43 AM
Vax1op369's Avatar
Default Gm Top Engine Cleaned how to use?
Hi Gentlemen, Recently purchase can of GM Top Cleaner 10-3015 32 OZ can. Read good bit of posts of various forums that this stuff is the ultimate cleaner. Read a few different ways on how to use it. Placing 2Oz in spark plug holes. Going throught pcv tube and letting it soak overnight. Any tips from on how to use it or how much to use Thanks.
Old Aug 25, 2024 | 07:22 PM
I use a fuel induction drip applicator with a valve to control to a slow drip. DIY, Start up and use any object for a pedal depressor between the seat and accelerator pedal to maintain 1000rpm over idle. Then walk away and check back in a half hour or so. When empty, shut engine off, disconnect and let hot soak 10 minutes, then drive it like you stole it.
Old Aug 27, 2024 | 09:16 AM
Vax1op369's Avatar
Thx 4 follow up. Going to run it through this weekend. Ill let you know how it comes out.
Old Aug 27, 2024 | 10:21 AM
Vax1op369's Avatar
Whats the max onces you have ever run into the throttle body?
Old Aug 31, 2024 | 07:19 PM
Vax1op369's Avatar
Update, First treatment I out 8 ounces into the drip can. Went for a drive after 50 minutes like I stole it haha, The acceleration was smoother and the engine much quieter at low rpm and even at 75 mph. Its designed for motorxycles but works perfectly in the evap valve above the trottle body. I did a second treatment of 12 onces. Letting it sit overnight. Will give you update 2mrw. Here is the drip I used on amazon.
Pit Posse PP2333 Motorcycle Portable Auxiliary Tank
Old Sep 2, 2024 | 11:06 AM
Vax1op369's Avatar
Update, ran 12 oz through on sencond time. Let it sit overnight. Was a little bit of smoke nothing crazy. I have cleaned it before with seafoam and have been running liqui moli valve clean over last few months. Next h2 i get ill run 16 oz first time. It did run even better smoothest acceleration so far. Cheers
Golden Hurricane
May 13, 2023 10:48 AM
wobaker
Jan 15, 2018 09:46 AM
Mr_Fulano
Dec 2, 2014 06:44 PM
Diablito
Feb 5, 2012 04:21 PM
