Custom Digital Display Interface
Old Sep 19, 2022 | 07:54 PM
  #71
Rotech's Avatar
why not use the button that comes through the cluster already? and replace it for a rotary encoder with push button. then you can cut costs by reusing the original housing and navigate GUI through the cluster plus have a use for the hole in the cluster. much simpler then integrating into steering controls although the original already uses steering controls. if you use the existing "retrofit" housing prototyping will go faster then designing a whole new cluster housing.... you can save that for version 2.
Creating a Google Docs for steering wheel parameters. Much work still ahead
Old Sep 19, 2022 | 07:57 PM
  #72
Rotech's Avatar
As MixManSC says "From a legal point of view, as far as I am aware as long as the replacement cluster displays and tracks mileage correct there is no legal issue with replacing it."
FYI this ebay seller seems to have dealt with the legal issues, perhaps this is the way...
I have the odometer PID from https://en.wikipedia.org/wiki/OBD-II_PIDs. I'll be testing unit on my H2 by the end of the week to make sure I'm getting the ODO readings
Old Sep 20, 2022 | 10:52 AM
  #73
Old Sep 20, 2022 | 03:42 PM
  #74
Rotech's Avatar
Interesting! Thanks for the share
Old Sep 25, 2022 | 03:43 PM
  #75
Rotech's Avatar
Here is something someone shared with me for H2 hummers. Figured I would share with everyone here
https://www.aliexpress.us/item/32568...d=o6xcG9wrOVow
Old Sep 26, 2022 | 12:06 PM
  #76
similar ones have popped up on the forum a few times. but usually not too much detail about them or what actually can interface with the H2. like steering controls and such or Bose interfacing.
Old Sep 26, 2022 | 01:09 PM
  #77
Rotech's Avatar
A guy on Facebook sent me the link. He's had it in his H2 going on 3 years. I'll ask him about steering controls and audio interfacing.
Old Sep 26, 2022 | 02:29 PM
  #78
Typically on Android based car stereos (which that huge screen one is) they interface like any other car stereo in a modern vehicle. In other words they will not directly work well - you still want to get a stereo interface and steering wheel interface if you want it to integrate with the factory amplifier, retain vehicle chimes, and have working steering wheel controls. They do have a steering wheel controls input as far as I know but you still need a vehicle specific interface to connect between. You could bypass the factory amp but that is complicated and a lot of work as all of the speaker wires terminate at the amp under the center console.
Old Sep 28, 2022 | 04:14 PM
  #79
Rotech's Avatar
Yes, he stated he never connected the steering controls to it because he didn't understand how to set it up. I'm trying to address this issue myself with a goal of plug and play for this digital display. Creating an app to make them changes looks more compelling at the moment
Old Sep 28, 2022 | 04:27 PM
  #80
Rotech's Avatar
