Custom Digital Display Interface
Old Oct 17, 2022 | 09:01 AM
  #91
Rotech's Avatar
Originally Posted by H2-SUT
GM went to the high speed CANBUS in 2008, the prior Hummer used the old style bus. This is also why you can only use the older LBZ/7 versions of the Duramax put into the pre 08 Hummers.
The 08/09 can be retrofitted with any of the newer Duramax's like the LMM, LML and L5P because their ECM's also use the high speed canbus and can be interfaced.
Along with the good comes a little bad, the newer bus makes the new Hummers more complicated and difficult to work on as well. Just about everything in the truck talks to the computers. Not only do you need a Tech II but also an MDI-2 and a laptop running TIS-2000 software to service and program all the systems.
Receiving information from the CanBus is easy. Sending data through CanBus becomes complicated. When it comes to the digital cluster I'm just extracting data and placing it in a clean user interface. I'll work on a version to check and clear codes but for now I'm developing a instrument cluster replacement. I have my app to check and clear codes for now. iPad version will be available soon as well
Old Oct 17, 2022 | 09:04 AM
  #92
Rotech's Avatar
Originally Posted by C57
So with an 08 a can move up in the line of diesel engines if I want. Thats so cool then . As far as the iPad or another pad, that seems like a pretty good deal then.
used iPads are inexpensive. The cheapest I found a 10.5 one on Facebook marketplace is $150. I don't have to focus on sourcing a display nor developing a pcb for a custom one. I can just focus on app development and upload to device with a much faster time to market.
Old Nov 7, 2022 | 10:48 AM
  #93
Brunob00's Avatar
The work you are doing looks fantastic! In addition to working with A&L Imports, which is a pretty good idea... check-in with the team at Predator. They perform Duramax conversions on H2s, and I am sure this would be an easy add-on sale to a conversion given the price point. I think the majority of both firm's volume is in 2008/2009 H2s, but you can confirm.
Old Nov 7, 2022 | 02:53 PM
  #94
oceanbrave's Avatar
FYI I think only 2008/9 models implemented CAN Bus (High Speed GMLAN network.) and all Instrument Clusters communicate via the low speed Data Link Class 2 Serial Bus.
Old Jan 5, 2023 | 05:13 PM
  #95
oceanbrave's Avatar
Rotech it's been a while, how's it going?
Old Jan 5, 2023 | 10:55 PM
  #96
Gavin Costigan's Avatar
This is the coolest digital display I’ve ever seen. W design.
Old Jan 7, 2023 | 12:21 PM
  #97
finall's Avatar
@Rotech Is this project dead?
crum55
Jan 31, 2024 12:33 PM
waltham41
Mar 5, 2022 06:08 PM
crum55
Feb 3, 2021 08:19 AM
oceanbrave
Aug 21, 2020 07:32 PM
rlbock
Oct 17, 2007 12:35 PM
