04 H2 hummer instrument cluster
Old Mar 4, 2022 | 04:59 PM
waltham41's Avatar
Default 04 H2 hummer instrument cluster
Just bought this. Guy before me though the cluster was bad replaced it with new cluster no luck.
Cluster will work fine then suddenly you will start it and nothing works not even the hi beam indicator. Turn signal indicators do work though.
Then randomly it starts working again when you start it.
Thoughts?
Old Mar 5, 2022 | 11:08 AM
My guess would be water ran behind the dash at some point and corroded a ground or the BCM or possibly a bad ignition switch.
Old Mar 5, 2022 | 06:08 PM
waltham41's Avatar
Ok. The carpet is wet in the driver's floor. I've noticed tat when the instrument cluster does work on startup there seems to always be about a two second pause after startup then all instruments jump to life.
crum55
Jan 31, 2024 12:33 PM
crum55
Feb 3, 2021 08:19 AM
RAHF
Oct 29, 2014 01:37 PM
hmmrgrl
31
Nov 15, 2007 05:39 AM
rlbock
Oct 17, 2007 12:35 PM
