Check engine light from Air to spring conversion
Old Jun 1, 2026 | 12:54 PM
  #31
Mark R's Avatar
Find a local shop to do the spring conversion, any competent shop can do it and save the $500 rental fee. Just don't expect them to worry about the light, you can research it as time permits.
Thanks Phil,I ave a local shop that does all my work. Tomorrow I'm going there to have new front anti sway bar bushings installed and the rear Spring upper and lower bushings along with the rear sway bar bushings. This is on the 65 Corvette. Then will make appointment to do the H2 Coil Springs.
I got some gidenance on turning off the DIC thang. I have seen and heard many different ways. The best way is the EBM module which I don't think is made for a 2009 and does not show anywhere I can find on the web???? Some 2003 thru 2007 H2 coil kts include the module but they will not sell you it or even know if it will work on 2008 and 2009.
Part of life.... be young... get old.... and pass away... same with the air ride...how long can it last. It's achilles heel[size=21px] is the electronic design. Way [/size]to complected.
Regards: Mark R
Old Jun 2, 2026 | 09:16 AM
  #32
all air ride comes to an end eventually. rubber and plastic under pressure can only last so long. thats why tires have date codes and a shelf life.
Old Jun 2, 2026 | 11:13 AM
  #33
Mark R's Avatar
Well said...I can't hang on for rubber and plastic. I'll go with steel and shocks and live my life worry free ....just just like I did when I dumped the last two weifs.
Tommy454
Jan 26, 2021 07:48 AM
surfcityred327
Feb 27, 2018 09:35 AM
H_drizzie
Dec 2, 2016 01:28 PM
sagev
Jan 17, 2013 11:41 AM
jasonsdad
Oct 29, 2012 09:10 PM
