Brake Rotor Shim?
Old Jun 28, 2016 | 05:28 AM
OWRLTD's Avatar
Default Brake Rotor Shim?
My brake caliper seized and chewed up my rotor. While looking for a replacement rotor, a shim kept showing up.
I've never heard of a rotor shim. Do I need one? Where does it go? What is it's function?
Thanks in advance.
Old Jun 28, 2016 | 08:06 AM
calif phil's Avatar
Offset shims are used to square up rotors. Unless your hub was machined wrong or has severe rust issues you should not need one.
Old Jan 20, 2020 | 08:52 AM
Heather Knowles's Avatar
Default Rotor shim
Is this the rotor shim?
Old Jan 21, 2020 | 08:07 AM
calif phil's Avatar
No, that is the hub flange, you do not have shims and do not need them.
Violet70092
Jan 8, 2014 08:08 AM
NJTEX
Apr 14, 2012 09:29 PM
super30067
Sep 24, 2009 09:30 PM
bblackburn
Mar 24, 2009 09:11 PM
Black_Impala
Nov 20, 2007 08:11 AM
