Another torsion bar adjustment thread
Old Nov 3, 2024 | 12:38 PM
RobertDez's Avatar
Default Another torsion bar adjustment thread
One of the last things to do on my 2003 H2 was to address the left front being 1/2 inch lower than the right front. Underneath I noticed the driver side torsion bar adjustment was out quite a bit further in the passenger side. Ended up going three full turns. And both adjustments bolts appear to be protruding the same amount now. Three full turns for that half inch because as you would adjust the driver side the right side will creep up a little. Got it dead even. Free alignment check yesterday because I had it aligned 2 months ago, the guy pointed out everything is still in spec although the camber on both sides has improved.
I think what I ran into is one of the adjustment bolts backing out over the past 21 years. I would surmise that as the suspension works and relieves torque on the torsion bar, I suppose that possibly could loosen it up over the years. It did turn quite easily, but I don't have any rust issues either. Alignment shop said that's not included on a normal four-wheel alignment.... Unless a customer asks. That is worth noting.
Old Nov 6, 2024 | 12:36 PM
Gavin Costigan's Avatar
I adjusted my torsion bars when i replaced the lower arms. Had the suspension perfectly settled, full tank of gas, and a 2 months later, the driver side sits half an inch lower. Its really frustrating.
Old Nov 6, 2024 | 03:51 PM
RobertDez's Avatar
I'm thinking it might be a good idea to put some thread locker on the adjustment bolt. Mine turned rather easily
Old Nov 10, 2024 | 10:48 PM
possibly. I marked mine and it didn’t move
Ranger Tom
Sep 16, 2024 02:08 PM
H3T Stick
Hummer H3T
Jun 11, 2023 04:52 PM
JPSH3
Feb 18, 2011 01:09 PM
Emptys_H3
Mar 11, 2010 12:52 PM
Rayvyn
May 9, 2006 09:47 AM
