2003 H2 water leaking and service airbag on
Old Jan 14, 2020 | 03:43 PM
bassenemy27's Avatar
Default 2003 H2 water leaking and service airbag on
I have a 2003 H2, 115K miles. I have placed RTV on the service marker lights and redone the door seals. Sunroof drains are fine and drain well. The issue I am having, after a huge rain, water basically showers you both driver and passenger sides from where the sunroof is, as well as running down the "A" pillar. Can anyone help me find this leak before it drives me insane?
Todd
Old Jan 14, 2020 | 03:44 PM
I forgot to add, since the last huge rain, the "service airbag" is on after I have dried out the Hummer. What could cause this as well?
Todd
Old Jan 14, 2020 | 03:52 PM
check your air bag module under the drivers seat for water damage or corrosion its bolted to the floor. as for the shower the drains can be disconnected at the sunroof if they "cleared your lines" with air.
Old Jan 14, 2020 | 03:58 PM
Inspect the area above high as you can go.
Old Jan 14, 2020 | 05:36 PM
The lines are clear, no air needed. Will check the module under the seat.
Old Jan 14, 2020 | 05:57 PM
Recheck your sunroof channel, pour water into that channel and observe where the water exits.
jbs45
Nov 1, 2021 11:38 AM
mhc100g
Hummer H3T
Jul 31, 2019 03:38 PM
Wfive
Apr 27, 2016 02:51 PM
mgurgone
Oct 31, 2011 10:16 AM
Mike
Sep 9, 2008 03:47 PM
