Wind Noise - Fixed
Old Feb 21, 2015 | 12:03 PM
oceanbrave's Avatar
Default Wind Noise - Fixed
Had really loud noises coming from the both sides of front of the car above 60mph. I read several posts about possibly sources e.g. the sunroof deflector, sunroof itself of the plastic covers (cowls) screwed to the front door posts, mine was the latter.
Suggested fixes ranged from plastic foam filler or glue etc however I discovered that thin rubber strips running top to bottom inside the cowls had become detached for around 4" or so at their ends. My guess these were acting like reeds in a pipe organ tuned to 60mph.
This was an easy fix, just cleaned de-greased them and stuck them back down with double-sided tape and the noise was gone!
Hope this helps someone
Old Feb 22, 2015 | 02:06 PM
mattdillon's Avatar
Good Post! My old 04' used to Flap in the Wind, when i got up to Higher Speeds like that! I ended up just putting a lil' Super Glue on it & it worked fine after that! Lol!
Old Feb 23, 2015 | 05:27 AM
elkgrunt's Avatar
Could you take a pic to show what cowl your talking about? Thank you in advance.
Old Feb 23, 2015 | 06:08 AM
LoJac963's Avatar
It is the trim on either side of the windshield. They are held in by screws and the weather stripping attaches at the bottom by a small notch. Remove them, clean the old rubber and attach double sided tape, foam, caulk, whatever you want then reinstall the trim pieces. Wind noise gone.
Although I think the windshield at the top middle is now making noise on mine. I need to mess with that next.
Old Feb 24, 2015 | 05:15 AM
elkgrunt's Avatar
Thank you,I will check this out.
Old Jun 25, 2018 | 04:04 PM
SheldenATXX's Avatar
I'm wondering if what your describing here is what i'm experiencing =
When I drive, and hit about 60mph, after about 5 minutes of driving, i'm getting a large wind-sucking sound which seems to be coming from the center of my windshield area. Sometimes it seems like its coming for the center of the hood...Sound familiar...?
Old Jun 26, 2018 | 12:21 PM
mcioci's Avatar
Yes. All Hummers have this issue. Quick and easy fix
Old Jun 26, 2018 | 08:47 PM
Ok Perfect - I'm unclear what to do next...How do I fix this..?
Old Jun 27, 2018 | 04:51 AM
oceanbrave's Avatar
Old Jun 29, 2018 | 01:33 PM
clsimmon's Avatar
Have a look here to make the repair
https://www.hummerforums.com/forum/h...driving-37804/
OCFDfyrfytr
Oct 20, 2016 10:16 PM
jonnieh3
Mar 2, 2016 11:59 AM
elron
19
Mar 28, 2010 12:28 PM
flrtrader
Nov 2, 2009 07:24 PM
mitch1
17
Mar 20, 2006 02:56 PM
