h2-wind noise in dash
Old Oct 16, 2009 | 06:49 AM
flrtrader's Avatar
Default h2-wind noise in dash
On the passenger side going down the X-way... 65 -75 mph I have a very anoying noise sounds like wind making a vibration on some plastic. Only way I can explain it. I have taken that side apart and find nothing loose, or anything blocking air flow. Anyone ever encountered this?
Thx
Old Oct 16, 2009 | 07:18 AM
vetteman40404's Avatar
YES!!!!!!! The vent covers outside the truck (the 2 little square things above the hood) vibrate. It took me a long time to find it because I thought that the noise was from inside the truck. I took them off and shimmed them with clear rubber. (The little pads that you would use to hold a glass coffee table from sliding.) Hope this helps you.
Old Oct 16, 2009 | 08:35 AM
calif phil's Avatar
On mine it was the long black trim on the windshield A pilar making the noise. I ran a bead of black silicone down the trim piece and it worked perfect.
Old Oct 26, 2009 | 09:10 PM
Fred's Hummer's Avatar
I had the exact same thing. Both A pillars use double back tape to hold them tightly to the windshield. Over time the tape stops sticking and the wind gets under them. Remove both A pillar windshield moldings from inside the doorways and replace the tape. The Hummer dealer here did it under the warrantee. now quiet at 70 mph. Hope that fixes yours.
Old Nov 2, 2009 | 07:24 PM
2007h3x's Avatar
We had this problem the first few weeks we had out truck. Turned out a screw in the roof lights had been stripped (probably by the previous owner) and the roof lights were vibrating into the windshield. The dealer replaced the light rack and everything is much better now. The screw was ground on the passenger side but you could hear the rattling throughout the truck.
markthetech
Nov 17, 2006 03:04 AM
weaponsgalore
Nov 4, 2006 12:46 AM
carissa
Apr 18, 2006 12:48 AM
mitch1
17
Mar 20, 2006 02:56 PM
ca_cop
Mar 10, 2006 12:35 PM
