Switched Cig Lighter Outlet?
Old Jan 18, 2007 | 10:09 PM
crank's Avatar
Default Switched Cig Lighter Outlet?
Does anyone know if the H3 has a switched (on when the ignition is on and off when the ignition is off) cigarette outlet in any one of the two outlets? I use a radar detector in one of them and it's always on causing the battery to die after a while sitting. There is two of them. One of them should be able to switch off.Other vehicles do....[:@]
Old Jan 18, 2007 | 10:26 PM
blackstangs281's Avatar
Default RE: Switched Cig Lighter Outlet?
Wire the radar detector direct. Run the wire up the post and across the headliner. Looks good and turns on and off with the car.
Old Jan 19, 2007 | 12:44 AM
importkiller's Avatar
very strange that a radar detector would cause your battery to die. I have mine hardwired as my gps is. Both are on 24/7 and my battery has never gone dead. I'd look into your battery or alternator if a small radar detector draw is killin it.
Old Jan 19, 2007 | 10:43 AM
crank's Avatar
Thanks Guys. I may do just that.
The battery has died on me twice in the last three weeks because it is very cold here (Pittsburgh) and it's not in use to charge it. I had my knee replaced 12/28 and can'tplay in the snowyet. That's the worse part.
Anyway...
I've called the local Hummer service dept and told them of the battery problem. I still have the Delco battery in it. Hopefully they will pick it up soon.
TNX.....
Old Jan 19, 2007 | 10:51 AM
Sugardaddy's Avatar
Crank, your battery needs replaced. Mine went dead twice last summer just from the dome lights being on as I cleaned th inside.
nelly27281
Jun 16, 2015 04:29 AM
SedonaBoundH3
Apr 13, 2012 02:21 PM
jbs45
May 17, 2011 10:55 AM
ramsay12
Apr 1, 2007 06:36 PM
crank
Mar 11, 2007 01:44 PM
