So I had marker lights installed...
Old Jan 21, 2007 | 07:58 PM
CCMDoc's Avatar
Default So I had marker lights installed...
And I noticed that the plastic caps over the screws were not all the way down. Couldn't get them to fit properly so took them off to find that the torxs screws were sticking up a bit. Tried to tighten them but they just spin - couldn't back them out either[:@].
What do they screw into ? I will be bringing it back to the dealer to take care of it, but now I want to know what they should have done and didn't.
Old Jan 22, 2007 | 09:42 PM
H3X442's Avatar
Default RE: So I had marker lights installed...
To install the marker lites you have to drill 6 holes across the roof and install these rivnuts it look like a sleave with threads for the screw on the inside and shoulder and knurl on the outside. You put the rivnut in the hole and use a bolt and serrated washer to tighten the the rivnutthismushrooms the rivnut on the inside of the roof. What can happen is you overtighten/undertighen the rivnut and it will not seat right causing what you have. Hopfully they can get another rivnut and just sink it in further. Steve
Old Jan 22, 2007 | 09:54 PM
CCMDoc's Avatar
ORIGINAL: H3X442
Yup, I assumed it was a rivnut problem and will find out tomorrow. You know these things are pretty easy to use if you take your time and put them in carefully and as you know are a real PIA to get improperly installed rivnuts out.I hate when this sort of thing happens -makes me lose faith in the service department. I just had to have them replace an improperly installed windshield (replaced due to a crack).
Thanks again Steve.
bobopotato
27
Jul 30, 2011 09:09 AM
robday
23
Apr 1, 2009 04:12 AM
Hunner
Feb 1, 2007 12:22 PM
Fallz
Nov 27, 2006 04:03 AM
CruisinCarAudio
May 25, 2006 04:14 AM
