Roof rack fitting
Old Jan 30, 2009 | 06:56 PM
ukpaul's Avatar
Default Roof rack fitting
Might seem a silly question but just bought oem style racks off ebay but how do you fit these things.
I've got the cross bars and then there is a bag with 2 keys and 8 black plastic washer type things.Sorry but thats the best way I can describe.
Any help would much appreciated.
Old Jan 30, 2009 | 07:51 PM
lucky19942001's Avatar
Smile
i just droped the rack into the rails on the roof and if i remember there is a bar to slide that locks them into place and then u put the end caps on and use the key to lock. it was simple and took 5 min
Old Jan 30, 2009 | 07:59 PM
ukpaul's Avatar
I did that but it's all real loose.
Thats why I thought those black circular washer type things had something to do with it.
Old Jan 30, 2009 | 10:48 PM
not sure what the washer u are talking about. when u have them in the rails ucan move them where u want and then if u like it there is a black bar that u move to tighten it and then its in place.then the caps are there to put on so no one can steal them thats what the key lock is for. so unless u have a diffrent bar then me u schould be set, here is a pic of mine i hope it works
Attached Thumbnails Roof rack fitting-dscf0001.jpg   Roof rack fitting-dscf0002.jpg   Roof rack fitting-dscf0003.jpg
Old Jan 31, 2009 | 08:19 AM
ukpaul's Avatar
Thanks for taking the time.
Mine are exactly like yours but when I slide that handle around they are still loose...I mean real loose !
I have been putting the racks in from the front(engaging into the channel) and then sliding back and turn the lever..
Here's a pic of those 8 black washer type things I was trying to explain..
aarrrgghhhh
Old Jan 31, 2009 | 07:13 PM
i dont recall those washers coming with mine. how loose are yours cause if try to jiggle them they might move left or right like half a inch which is nothing , u can try emailing the seller and asking if they no what the washers are for or if he has instructions that they forgot to include.
Old Jan 31, 2009 | 07:24 PM
u said in your first post u bought oem style. so are they oem or they look like oem cause i looked up the oem roof racks whick i have and this is what they say comes with it .Package contains 2 rails, 4 end caps and 4 keys. i bought mine off ebay but i made sure be4 i bought that they were officily a gm product and matched up the part numbers so all i can think of now is u have roof racks that are not made by gm but some 1 else and that ther design is alittle diffrent. good luk and let me no if u figgure it out
Old Jan 31, 2009 | 07:32 PM
Slim's Avatar
Lucky,
Do you recall how much the rack you got on ebay cost? The dealer cost is way too much for me.
Thanks,
Scott
Old Jan 31, 2009 | 10:49 PM
ukpaul's Avatar
Right, I got it..
I took the lever assembly apart and the spring that is on the shaft had worked it's way thru the hole towards the lever which was causing the problem.Hence, when you turned the lever to tighten down it didn't have enough travel to make it fix on solid...
Thanks for all your help lucky19942001...
What I have done isn't perfect but it's good enough..
Old Jan 31, 2009 | 11:15 PM
hey slim i think i paid $175 shiped and that was a year ago. it was from a genuine gm reseller that was doing a inventory clearance, so basically he had to many and needed to sell some so they where priced to sell. they where brand new and the box was sealed and i saw the gm sticker on the box with barcode and part number so i new it was the real deal. just search ebay and be patien,when i was looking to buy i spent a month or so looking and then i found a price i like
gotafish
Nov 2, 2011 11:50 AM
paultimmins
Mar 3, 2011 09:43 AM
drew2468
Sep 26, 2008 01:21 PM
finall
Apr 28, 2008 10:38 AM
CruisinCarAudio
Apr 15, 2006 03:52 AM
