Need help with grease fitting (zerk)!
Old Apr 23, 2008 | 09:06 PM
finall's Avatar
Default Need help with grease fitting (zerk)!
Just found the well-hidden 11th grease point on the upper part of the idler arm. Need to take off the front skid plate just to feel it with your hand. Can't see it at all, as it is recessed in a well of steel around it.
Impossible to lube, as it has a straight fitting, with about 1/2" space around it before it contacts a wall. I need to replace it with a 90 degree fitting. So I took the nipple off. But my 90 degree zerks (grease nipples) do not fit.
Anyone know the thread pitch on the grease fittings on a 07 H2? There are hundreds of sizes available in metric, standard, self-tapping, etc.
I called the local auto parts store, and they don't know. Help!
Old Apr 24, 2008 | 01:36 AM
amp88's Avatar
Default RE: Need help with grease fitting (zerk)!
Call the Hummer dealer...they should be able to tell you.
Old Apr 24, 2008 | 08:16 AM
Take the one you took off the H2 to the hardware store and find a nut to fit on the thread pattern, then get the zerk matching that thread?
Old Apr 24, 2008 | 10:30 AM
finall's Avatar
Hummer dealer does not know the thread pitch on any part. They strictly go by part numbers. The threads are tapered, and not so many, so putting a nut on it did not work. But thanks for the ideas guys!
But I found out that the thread pitch is 28G or 0.9 metric. Both are almost the same and will interchange. Got it in there. I could finally lube that point.
Old Apr 28, 2008 | 10:38 AM
finall's Avatar
Ok, figured it out. It is a 0.9 or 28G, both are really close and either the standard thread or metric will fit.
drtom
Dec 4, 2010 09:44 PM
jklee
Sep 15, 2010 08:50 PM
Luigi
Aug 7, 2010 08:13 PM
HummerGuy
80
Apr 23, 2008 07:29 PM
dizzy
Sep 16, 2007 11:37 PM
