fitting 3.5 aftermarket intake on 3.7??
Old Sep 26, 2008 | 11:48 AM
drew2468's Avatar
Default fitting 3.5 aftermarket intake on 3.7??
does anyone know if you can slightly modify or what you might have to do in order to fit an aftermarket intake from a 3.5 on to a 3.7 h3 motor?
Drew
Old Sep 26, 2008 | 01:21 PM
Default RE: fitting 3.5 aftermarket intake on 3.7??
It is not the motor size itself, there are two differences between the 3.5L (2006) and 3.7L (2007). The MAF sensoris different and they are not interchangable, a 2007 MAF will not fit the hole and make a seal in a 2006. There is also an emissions breather on the front of the air filter box on the 2007 that is not present on the 2006, so you have to deal with that open hose with a small filter or the like to prevent crud and water from being sucked in it.
So it is more than a slight modification, it would be an irreversible bastardization of sorts. Good luck.
gotafish
Nov 2, 2011 11:50 AM
paultimmins
Mar 3, 2011 09:43 AM
ukpaul
Jan 31, 2009 11:15 PM
finall
Apr 28, 2008 10:38 AM
CruisinCarAudio
Apr 15, 2006 03:52 AM
