Rear suspension squat
Checking the TECH2 against documentation it turns out the pressure is monitored (see 18+19 below)
The TECH lists 28 fields as follows (inc some real values for reference):-
- Ignition = On
- Ignition 3 = 11.5 Volts
- Battery Voltage Signal = 11.51Volts
- Ride Height Status Signal = Normal
- ERH Switch = Released (dash switch)
- ERH Lamp Command = Off
- Inflator Switch Lamp Command = Off (Tyre Inflator in back)
- Inflator Switch = Released
- Compressor relay = Off
- ALC Exhaust Solenoid = Inactive
- Right Isolation Valve = Inactive
- Left Isolation Valve = Inactive
- Total Valve Current = 0 mA
- Right Height Sensor = 2.50 Volts
- Left Height Sensor = 2.50 Volts
- Height Sensor Current = 22 mA
- Height Sensor Supply Status = On
- Rear Leveling Air Pressure = 41 psi
- Rear Leveling Air Pressure = 0.41 Volts (Scale 100:1?)
- Compressor 1 Temperature = OK
- Compressor 2 Temperature = OK
- Door Switch = Closed
- Trim Height Learned = Yes (No generates DTC C0569)
- Park Switch = On (not Controller func)
- Neutral Switch = Off (not Controller func)
- Engine Running = No (not Controller func)
- Number of DTC(s) = 0
- Vehicle Speed = 0 mph (not Controller func)
th3_villain
Oct 7, 2009 08:38 AM
Mikkofin
Feb 1, 2008 02:01 AM
