Rear suspension diff torque
Old Jun 21, 2019 | 06:46 PM
myrddin's Avatar
Default Rear suspension diff torque
Hey folks I am getting contradictory results while looking up some torque values. I need to know the torque settings for the following:
Rear axle diff cover bolts
Rear axle diff cover fill plug
Rear sway bar end link bolts top and bottom
Rear track bar bolts
I have seen random numbers and I thought if I post here and get random numbers at least we can talk about it.
I see 29 fp for the diff cover bolts
I see 77 fp for the track bar bolts
I see 24 fp for the stabilizer end links (top and bottom)
I see 24 fp for the diff cover fill plug
Thoughts?
Old Jun 21, 2019 | 07:45 PM
I just did all that a few months ago. I just used my 1/4" Milwaukee m18 fuel impact screw gun then snugged everything down with a ratchet by feel. so far nothing loose and nothing leaking. the heavier stuff I just used my Milwaukee 1/2 M18 impact gun till I saw it stopped turning the nut just a few chug a chuggas. so yeah no clue either even though I have a service manual somewhere on a computer. now if the parts where aluminum then yeah make sure to torque to value. lol learned the hard way
Old Jun 22, 2019 | 08:04 AM
myrddin's Avatar
Gotcha. I guess I’ll try the numbers I found. I don’t have any air tools. Guessing it should be ok. I did pull them from a service manual page I found online. Hopefully it’s legit.
Old Jun 22, 2019 | 06:19 PM
mine where 18 volt battery powered Milwaukee. I don't have a compressor that can handle air tools.
Old Jun 22, 2019 | 07:53 PM
myrddin's Avatar
Gotcha. I ended up going with the numbers I found. Worked out ok. Time will tell for sure.
Thank you for your feedback!
Old Jun 22, 2019 | 11:57 PM
legerwn's Avatar
what year truck?
Old Jun 23, 2019 | 12:14 AM
legerwn's Avatar
for the 08 & 09 trucks the Diff cover bolts are 30 lb ft, diff drain plug 24 lb ft, stabilizer bar links 24 lb ft, track bar nut and bolt 77 lb ft
all specs came from Alldatadiy.com
Neal
Old Jun 23, 2019 | 08:45 AM
myrddin's Avatar
2005 I’ll check that site. Thanks for the info!
Synthetickiller
Dec 12, 2024 01:42 PM
TAINTER
Jun 7, 2015 09:48 AM
mb7050
Sep 13, 2014 12:56 PM
CWS
37
Mar 18, 2012 08:07 AM
sfgiantsfan9
27
Apr 24, 2011 01:13 AM
