Radiator trans cooler mixing fluids
Old Nov 2, 2014 | 10:37 AM
YHummer's Avatar
Default Radiator trans cooler mixing fluids
Hello Forum Members,
I recently found a crack on top of the OEM radiator.
So I went to ebay and bought the the "best deal" radiator available for $99 shipped.
I did the replacement yesterday to find out the bottom oil fitting was leaking, so I tightened a bit and it still leaked. I figure the O-ring on the fittinbg was chewed up. So I loosened the fitting to inspect the o-ring and coolant(dex-cool)starts dripping (i dont even know how since its a new radiator but I guess you get what you pay for.
I contacted the seller and gave a negative review and hope he can either refund me or get me a replacement.
Nonetheless lesson learned, but I was wondering if anybody ever had this issue? Is there a connection from the AT cooler to the Rad?
Old Nov 2, 2014 | 06:04 PM
woodwardsh3's Avatar
what brand was it, i just bought a silla and had not installed it yet
Old Nov 2, 2014 | 07:37 PM
The cooler and fittings are molded into the rad. The seals are part of the lines, You fvck'd that rad up! oh well get another one...
LIVE AND LEARN
Old Nov 3, 2014 | 03:13 PM
YHummer's Avatar
Better said: the radiator is weak as fyck as I only thight the fitting until it was snug enough. Trust me Ive worked on several projects and I know how tight is too much.
Old Nov 5, 2014 | 02:39 PM
amrg's Avatar
If you're at it, why not add an external trans cooler, independent from the Radiator. It will keep your trans temps much lower, cheap insurance from the cross contamination that some people get when the radiator fails and coolant gets passed to the oil part and into the transmission (very bad for the trans).
If your living in cold climate, get a bypass for it too!
eleewhm
36
Mar 16, 2015 06:43 PM
groomsxxx
Feb 27, 2014 04:11 PM
lex
Dec 27, 2013 08:57 AM
greg260
Aug 17, 2013 04:28 PM
giant H2
Sep 25, 2010 09:30 AM
