Leak near Onstar Mic
Old Aug 15, 2012 | 09:16 AM
Mikethecop6's Avatar
A search would have found it for you.
https://www.hummerforums.com/forum/h...n-tubes-28548/
Saw that yesterday...lol. Thanks!
Old Aug 16, 2012 | 01:26 PM
lifesavr65's Avatar
Finally did it !!!!! Took about an hour (kept looking for white tube on drivers side, it's black....) pulled the firewall plugs and cut out the "X". Drains run great and hopefully this issue is resolved. Also flushed lines with degreaser to get the crud out.....
Old Aug 26, 2012 | 02:44 PM
jcantu's Avatar
Need help I got a water leake dripping from Onstare Mic, How exactlly do I unclogg the drane holes?
Old Aug 28, 2012 | 08:43 AM
Old Aug 29, 2012 | 02:23 PM
lifesavr65's Avatar
update:
yes this fix worked. A few days afterwards it rained, wait, DUMPED like 2" in an hour or two...... It was bad.... BUT my H3 was bone dry on the inside....
I wanted to test it out, but this was a true test......phewwww
(cant say the same for the clowns who were driving through standing water in their cars and flooded them.....then called "911" so we could go pull them out)
Old Aug 29, 2012 | 02:35 PM
lifesavr65's Avatar
Old Aug 29, 2012 | 02:38 PM
lifesavr65's Avatar
but once you get the grommets out of the firewall take a screwdriver or some tool and "punch out" the membrane that is over the end of the grommet.... the easiest way to get the passenger side off is to also take off the vent (it pops off) and look toward the firewall, follow the large white tube to the grommet and just pull it out...
Old Aug 31, 2012 | 09:39 PM
lifesavr65's Avatar
Here's the post I was looking for. Just follow the directions...
Hummer X Forum • View topic - H3 Sunroof Drain Tubes
Old Sep 3, 2012 | 10:44 AM
heyttsguy's Avatar
Default roof rack channel bolts leak
just a heads up to keep an eye on the factory roof rack channel bolts as well. noticed a bit of a leak coming from mine. unscrewed all the bolts and sealed them up with silicone on the threads. seems to have worked. there was a bit of rust on all the threads so water may have been an issue with all of them at some point.
Old Sep 6, 2012 | 08:58 AM
bosoxdew's Avatar
I did the same thing as a precautionary measurement
CreekH3
Feb 24, 2015 08:46 PM
Selandbe
Nov 25, 2014 04:24 PM
Autumn Walker
Dec 20, 2012 10:21 AM
Marauder
Sep 10, 2008 03:32 PM
