Knock sensors and what else
Old Aug 8, 2014 | 08:11 AM
tharber's Avatar
Default Knock sensors and what else
I have to replace the knock sensors in my 05 H2. I've cleared the codes too many times and now just need to get it done.
Since the intake has to be pulled, what else would you replace or upgrade while doing so? I think I'm going to pull the hood off to make it easier.
Tim
Old Aug 10, 2014 | 01:38 PM
hmer's Avatar
Just yesterday i had this code pop up on my H2 . I would replace Anything you see that may be about to give up around that area since you are going to take it a part ...
Old Aug 10, 2014 | 04:31 PM
Signal25's Avatar
IMHO, knock sensors are fairly straight forward.
Just put some RTV on the "caps" when you re-install those to keep water, etc.
Old Aug 10, 2014 | 04:32 PM
Signal25's Avatar
Id do it neater then this, because I am ****, but this is what I am talking about.
Old Aug 10, 2014 | 07:04 PM
LoJac963's Avatar
Tim
LS2/3 heads, port and polish everything, larger valves, upgraded roller rockers, custom ground cam, LT headers, FAST intake mani, etc.....
Obviously I'm joking. Unless you're having other issues I wouldn't worry about upgrading anything else.
Old Aug 12, 2014 | 02:12 PM
ak47dennis's Avatar
Tim
Don't forget the updated GM harness, more then likely yours will disintegrate when you try and get them off the sensors. The dealers have the harness & sensors in stock.
I have done knock sensors/harness replacement twice on H2's no need to pull the hood. Don't forget new intake gaskets and carb & brake cleaner to hose out the intake.
Old Sep 28, 2014 | 12:18 PM
millerlanc's Avatar
I have an 04 h2 with a bad knock sensor. Whats the cost of having them replaced?
madmayo
Apr 7, 2015 03:22 PM
bighead
Aug 2, 2009 08:54 PM
alex2mil
16
May 21, 2008 06:40 PM
xzachx2112
21
Jan 30, 2008 07:57 AM
Body Armor Guy
Jan 18, 2008 02:59 AM
