Intake gasket question
Old Jan 23, 2009 | 01:36 PM
majhero's Avatar
Default Intake gasket question
2003 H2 110k miles. My engine light comes on, and stays on. They did a smoke test, and said the intake gasket is leaking. it needs to be replaced. He said it is common on the GM's
Has anyone else had this problem?
Old Jan 24, 2009 | 04:42 AM
madmike's Avatar
Banned
Default RE: Intake gasket question
I have only had a problem with my throttle body gasket leaking once in a TPI GM motor I had. New to the Hummer scene but the engine is basically the same. Other intake leaks were vaccum hoses that were attached to the intake. Id get a second opinion. Might just be a bad hose. Would a intake leak cause the comp to throw a code? I would think it would just be running a bit lean/higher than normal idle. When the engine light comes on, this means a code has been stored in the computer. Or this is usually the case on comp controlled vehicles. The code tells alot if you can decipher it with a manual. I just got my H2 a couple of weeks ago so I havent even got the manual yet.
Old Jan 24, 2009 | 06:01 PM
HumminNBoatin's Avatar
My H2 is at the dealer for this same reason right now. I was getting codes
P0101 (Mass Air Flow out of range)
P0171-Bank 1 too lean
P0174- Bank 2 too lean
I replaced MAF and air filter and had no sucess. I will post the outcome on Monday when I hear from the dealer.
Old Feb 2, 2009 | 10:33 AM
majhero's Avatar
I had the gasket replaced. So far no engine light. I guess that was the problem.
madmayo
Apr 7, 2015 03:22 PM
RavenH3
Jul 25, 2011 10:19 AM
psych0
May 26, 2010 06:31 PM
silverwarrior
Nov 11, 2007 05:31 PM
