Have to set the temp to 90 to get heat! HELP!
Old Dec 8, 2013 | 10:37 PM
victoriag26's Avatar
Default Have to set the temp to 90 to get heat! HELP!
I have a 2004 H2, just out of the blue the heater quit putting out heat. Just playing around I kept turning the *****, it wasn't until I turned it up to 90 that I had heat coming out of the vents. If I turn it down even one click I have no heat. With the cold temps her in Oregon right now and having to be constantly adjusting the **** it's getting annoying!
Has anyone else experienced this problem?
Old Dec 9, 2013 | 08:01 AM
ak47dennis's Avatar
Their is a board that controls the air mixture when you turn your heat below high or 90 degrees. My 06 had this issue years ago, it was explained to me by the dealer like this. If your heat isn't on high (90 degree) it's running the a/c to mix that air with the warm in order to maintain your cabin temp at your setting. When I asked why run the a/c and not use the vent air they told me cause it would be impossible to regulate since the outside can and will fluctuate as you simply drive down the road. The dealer called it a mixer board and said it regulates the amount of a/c with the heat.
Old Dec 10, 2013 | 10:41 AM
Thumbs up
Okay, I've read about that...so is it a reset or replacement issue? Thank you for replying!
Old Dec 10, 2013 | 10:48 AM
ak47dennis's Avatar
I would say you need the board.
Old Nov 16, 2014 | 12:41 PM
Thank you for the info. I'll start pricing new boards.
danaw
Oct 18, 2014 10:58 PM
hollywood_x
Oct 7, 2011 05:02 PM
pvmh3
Sep 7, 2011 08:30 AM
racin
Aug 16, 2010 07:58 PM
hearseman
Aug 5, 2010 09:26 PM
