H3 help!!!!
Old 05-13-2019, 06:28 PM
JamieNavaro's Avatar
Default H3 help!!!!
So if someone has any info I need help! I was driving my H3 down the highway and all of the sudden I lost power to the wheels and and my engine reved up like I was in neutral and was pushing the gas. I pulled over and put it in park and when I did it made a loud grinding noise and idled down. I turned it off and had it towed home. So Later that day when I got back home I cranked it and when I put it in drive and it just revs up with no power to the wheels and again made a loud grinding noise when I put it in park. I tried it one more time and before I put it in drive I switched to 4 WD High lock then I put it in drive and could drive it in my yard no problem. Does anyone know what this might be?
Old 05-14-2019, 07:39 AM
Front diff Ring and pinion, half shaft, intermediate shaft, front prop shaft.
Have you crawled under it to assess is any damage or fluid leaking?
Old 05-14-2019, 08:34 AM
Miles would be important to know when asking any question.
Your Transmission or transfer case is cooked and you need a rebuild or replacement.
Old 05-14-2019, 06:50 PM
Check fluids and look for metallic flakes.
Pull the trans dipstick and wipe on a white paper towel and post picture.
After that,drain the fluid at the front differential and post a picture:
Old 05-14-2019, 08:41 PM
I will tomorrow thank you!
Old 05-15-2019, 09:49 AM
233k miles
choochmalooch's Avatar
Cool
Sounds like a transfer case issue.
Old 05-15-2019, 04:08 PM
Originally Posted by JamieNavaro
233k miles
Trans definitely needs flushed, however that is not your problem. Did you drain the fluid in the front diff and transfer case?
Old 05-15-2019, 04:11 PM
I’ll be able to do that tomorrow morning. I had a lot on my plate today I had to take care of. I will post pics of what comes out. Thanks again!
Old 05-16-2019, 02:54 PM
650Hawk's Avatar
Could b ewrong I suppose, but my money is on the transfer case encoder motor. That's the exact symptoms I have seen before with my wife's Tahoe. Hint, OEM encoder motor only, or you will be replacing it again.
Quick Reply: H3 help!!!!
