H3 braking on its own and "ABS Fault/Stability System Failed"
Old Nov 17, 2013 | 02:00 PM
mismatch's Avatar
Default H3 braking on its own and "ABS Fault/Stability System Failed"
Well, here we go. After driving around checking out storm damage to the area, a "ABS Fault/Stability System Failed" message came on. There were no codes on my Scan gauge. Everything seemed fine until I turned the truck off then on. After driving one block the brake pedal began making a popping noise similar to when the ABS kicks on. A few seconds later a louder popping type noise came from the drivers front wheel and the truck slowed quickly as if the brakes were automatically being applied. Being only a block from home I decided to limp it home. Interestingly enough, this only happened when in drive, not reverse or neutral. I found this out by accelerating until it happened again and again and popped the trans into neutral. Backing in the driveway was no problem either.
I have found links here, but not with the brakes seemingly automatically being applied......thoughts...? Oh yeah, the truck is an '06 H3 Lux with and auto trans.
Old Nov 17, 2013 | 08:50 PM
skeeter's Avatar
when mine did that, my wheel bearings were worn. I would have it checked, adn replace immediately
Old Nov 22, 2013 | 08:51 AM
mismatch's Avatar
Throttle control sensor or throttle position sensor, either way it malfunctioned and the ABS was being applied to the affected wheel.
Shorty
Jun 23, 2015 09:12 AM
wpduffey
19
Oct 2, 2014 07:14 AM
Alex2012
Nov 16, 2013 06:34 PM
mosesjel
May 26, 2011 11:05 AM
