mismatch |
11-17-2013 02:00 PM |
H3 braking on its own and "ABS Fault/Stability System Failed"
Well, here we go. After driving around checking out storm damage to the area, a "ABS Fault/Stability System Failed" message came on. There were no codes on my Scan gauge. Everything seemed fine until I turned the truck off then on. After driving one block the brake pedal began making a popping noise similar to when the ABS kicks on. A few seconds later a louder popping type noise came from the drivers front wheel and the truck slowed quickly as if the brakes were automatically being applied. Being only a block from home I decided to limp it home. Interestingly enough, this only happened when in drive, not reverse or neutral. I found this out by accelerating until it happened again and again and popped the trans into neutral. Backing in the driveway was no problem either.
I have found links here, but not with the brakes seemingly automatically being applied......thoughts...? Oh yeah, the truck is an '06 H3 Lux with and auto trans.
