H2 Shifter upgrade
Old Sep 1, 2023 | 10:43 AM
812sf's Avatar
Default H2 Shifter upgrade
I always disliked the way the H2 shifter sounds clicky and to me cheap when shifting. I'm big on how things sound and feel. Like the sound a good solid door when closing or opening. I'm upgrading the interior of my H2 and posted some things like rebuilding the door panels. Last night I took the shifter out and studied how it works and what is making the noise. There are two things. One is metal pin on the shift rod that slams into the upper detents. I used a piece of wire shrink tube on and shrunk it to the pins. This keeps it from slamming. The second area is the main detent cam that has a piece of spring metal that provides some of the feel when moving from park to drive and back. I attached layers of felt tape and added some 3m spray adhesive between layers. I then added some white lithium grease and now it's smooth and sounds like quality. I think adding some rubber coating to the end of the spring would help also but I didn't have any. Not sure how long it will last but it's worth a try.
hummer_on_fumes
Mar 24, 2022 04:31 PM
hummer_on_fumes
Jan 27, 2018 11:01 AM
dougie
May 20, 2016 01:40 PM
lifesavr65
Jul 4, 2013 09:53 PM
IceIsFun
Feb 14, 2010 04:50 AM
