final wheel choices!
Old Apr 15, 2007 | 02:14 PM
jm4490's Avatar
Default final wheel choices!
Does anybody happen to know what the centerbore is in mm ?
My final wheel choices are the both the same wheel but 2 different offsets and backspacing .
#1 22x9.0 with a +20 offset and 5.79 backspace and the tires are a 325/50/22
#222x9.0 with a +35 offset and 6.38 backspace and the tires are a 325/50/22
Both a 110mm bore
I have been looking alot for wheels and want them to look right the first time. I don't want them sticking Way out or rubbing ..
Old Apr 15, 2007 | 02:49 PM
Gunner_45's Avatar
Default RE: final wheel choices!
Brother, I feel your pain.....I did the same when looking for my wheels.
What style did you finally decide on?
As for the bore diameter, it is critical....4WP's got mine wrong the first time ! ! !
They didn’t discover the error UNTILL AFTER everything had been dis-mounted,
re-mounted and the TPS modules swapped over.....I wanted to cry....But, they did
make it right.....Ultimately; if it will fit on a full size GM it will fit your hub.
I bet if you sweet talk ImportKiller, he can provide you with the exact bore size.
His Wheel-Fu is very strong.
I ended up with a 17X9 inch wheel, 4.5 inches back spacing and a 12.50X33 tire...Sticks out about 2 inches or so.
One last, un-asked for piece of advice....If you are choosing a cast wheel as opposed to a forged, make sure you
see it in person first ! ! What I found, was that the wonderful looking forged wheel with all the cool detents and crisp lines,
did not look the same in person as it did in the catalog. None of the edges were as sharp nor the details as defined as
they looked in the pics and the chrome was not quite as bright as you would expect.
Good luck.
Old Apr 15, 2007 | 08:22 PM
jm4490's Avatar
Akuza 381
Old Apr 15, 2007 | 09:25 PM
Gunner_45's Avatar
Sweet.
Old Apr 16, 2007 | 12:06 AM
canuckZr2's Avatar
OK i have a Question why do you say +20 offset and 5.79in back space when the +20mm is the measurement form the wheel mounting flange to the outside of the rim and backspace is the measurement from the inside bead to the wheel mounting flange.What i mean is are you not repeating your selves?
Old Apr 16, 2007 | 01:44 AM
BB's Avatar
BB
Offset is the distance from the mounting surface to the rim's true centerline.
Old Apr 16, 2007 | 01:55 AM
canuckZr2's Avatar
that what i ment sorry
Old Apr 16, 2007 | 12:41 PM
littlehummerboy's Avatar
Those rims will look great no doubt!
Old Jun 10, 2007 | 11:11 PM
twenty8eight's Avatar
JM....did you wind up buying these wheels?
If so what size did u go with?
Also, If you dont mind me asking what did you pay and where did you get them???
I'm looking all over for a nice set of 22"s for my 03 H2....
Old Jun 11, 2007 | 03:14 AM
ORIGINAL: jm4490
Akuza 381
SWEET!!!!
LawWyfe
106
Oct 4, 2007 08:15 AM
2luke2
19
Mar 25, 2007 09:52 PM
GH3
20
Mar 4, 2007 12:38 AM
davyo
Aug 2, 2006 07:04 AM
Cruizer
27
Apr 9, 2006 03:48 AM
