Engine cuts out
Old Dec 17, 2008 | 02:40 PM
racegun's Avatar
Default Engine cuts out
When I am traveling around 52mph my engine starts to cut out until I get to about 55mph. It only does this when I am travelingsteady at around 52mph. It never does it when accelerating thru 50-55mph. Any thoughts?
Old Dec 18, 2008 | 08:57 AM
calif phil's Avatar
Default RE: Engine cuts out
Sounds like a miss fire. Have you checked the spark plugs and or wires, a fuel filter and some quality injector cleaner might not be a bad idea as well. I use Amsoil P.I. or Chevron Techron cleaner in mine.
Old Dec 18, 2008 | 12:51 PM
racegun's Avatar
I have tried injector cleaner and a new fuel filter and it still does it. I'll check the others later. Thanks
Old Jan 20, 2009 | 02:07 PM
racegun's Avatar
I pulled the spark plugs and they are fine. Ran some techron fuel cleaner thru it and replaced the spark plug wires and it still does it!!!!
Help please?????????????????????????????
Old Jan 21, 2009 | 09:05 AM
calif phil's Avatar
Could it be your torque converter going into lockup? Try and lightly apply the brake pedal just enough to make the brake lights come on at the speed you notice the misfire. That will disengage the lock up converter. If the problem goes away then you know it's just the converter going into lockup and nothing to worry about. If it is missing you should have a misfire code stored in the ECM and getting the truck scanned will point you to what cylinder is the culprit.
Old Jan 26, 2009 | 12:44 PM
racegun's Avatar
Not the torque coverter. I'll take it in to have it scanned.
Cashville
Dec 6, 2013 06:56 AM
bigmoe1315
Feb 8, 2011 09:54 PM
bigmoe1315
Oct 6, 2010 10:03 PM
4U2NV
Jun 15, 2010 12:34 AM
Ken06H3
Nov 22, 2006 09:38 PM
