dome lights stay on!
Old Sep 18, 2014 | 05:07 AM
dyydjbb's Avatar
Default dome lights stay on!
I have a 07' H3 that recently came back from the dealer having a new sunroof installed. Two days later my dome lights stay on all the time. The only way I found to turn them off is disconnect the battery for a few seconds. Lights come back on when doors are opened so I pulled the bulbs. Anyone have any help? No door adjar lights on.
Old Sep 18, 2014 | 11:12 AM
happythree's Avatar
new trouble?, rule one, always look at the last place a "professional" did anything.
check wires in that area.
i make a living fixing jobs that pro builders took shortcuts on. ez work, just do it right!
Old Sep 18, 2014 | 01:42 PM
This is really a dome question.
Check the door jamb switches/sensors.
Old Sep 18, 2014 | 03:19 PM
RKSmith163's Avatar
If it were a door jamb switch, he should have the DOOR indicator on his DIC although stranger things have happened.
Old Sep 18, 2014 | 03:27 PM
If it were me, I'd be back at the dealer telling them to fix the problem they created.
Old Sep 18, 2014 | 03:39 PM
RKSmith163's Avatar
Ditto on that. Happythree is right on this one. A wise man once told me, the first place to look is the last place you messed with.
Old Sep 18, 2014 | 04:25 PM
Shayne100's Avatar
I have been searching the web for known common faults of the H2 and among them is the ignition switch will need replacing . I realized mine does after finding the battery dead 2 mornings in a row . Turning the ignition off doesn't always turn everything off , sometimes the onestar and mileage stay lit other times the roof lights stay on . Rattle the key in the ignition turning it on and off . If it works sometimes but not others there's your answer .
Aside from that the sunroof is designed to break - the rain drains are designed to block - the door seals and roof lights are designed to leak - the gas filler cap is designed to fail which will put your check engine light on .
Old Sep 18, 2014 | 08:02 PM
Just spin the dome light dial all the way down..
Old Sep 18, 2014 | 08:13 PM
Rule that out, I leave my doors open all the time, dome light only stays on for a short time, auto off, however there is a manual switch on the dashboard, to overide.
Old Sep 18, 2014 | 08:18 PM
You need help, possibly medical assistance and more so a KIA.
