dome lights stay on!
I have a 07' H3 that recently came back from the dealer having a new sunroof installed. Two days later my dome lights stay on all the time. The only way I found to turn them off is disconnect the battery for a few seconds. Lights come back on when doors are opened so I pulled the bulbs. Anyone have any help? No door adjar lights on.
new trouble?, rule one, always look at the last place a "professional" did anything.
check wires in that area. i make a living fixing jobs that pro builders took shortcuts on. ez work, just do it right! |
This is really a dome question. :D
Check the door jamb switches/sensors. |
(Post 317245)
If it were me, I'd be back at the dealer telling them to fix the problem they created.
(Post 317249)
I have been searching the web for known common faults of the H2 and among them is the ignition switch will need replacing . I realized mine does after finding the battery dead 2 mornings in a row . Turning the ignition off doesn't always turn everything off , sometimes the onestar and mileage stay lit other times the roof lights stay on . Rattle the key in the ignition turning it on and off . If it works sometimes but not others there's your answer .
Aside from that the sunroof is designed to break - the rain drains are designed to block - the door seals and roof lights are designed to leak - the gas filler cap is designed to fail which will put your check engine light on . |
Just spin the dome light dial all the way down..
(Post 317245)
Originally Posted by Shayne100
(Post 317251)
Aside from that the sunroof is designed to break - the rain drains are designed to block - the door seals and roof lights are designed to leak - the gas filler cap is designed to fail which will put your check engine light on . You need help, possibly medical assistance and more so a KIA. :confused: |
