Coolant leaking at record speed
Old May 6, 2015 | 11:25 AM
AR15wheeler's Avatar
Default Coolant leaking at record speed
Leaking while truck is not running. Looks to be coming from behind water pump pulley. Reservoirs level dropping 1 inch every 30 minutes. Is this a typical sign of the water pump seal going bad? Help!!!
Old May 6, 2015 | 12:43 PM
woodwardsh3's Avatar
Yep, And it is not to hard to change
Old May 6, 2015 | 03:34 PM
The most difficult fan to remove ever EVER! Took 2.5 hours. (Didn't have the correct tool) can't believe all that coolant coming from that weep hole?
Old May 6, 2015 | 06:22 PM
Robert May's Avatar
I know this is a little late but FYI you can actually put tension on the belt with the belt tensioner while you break the bolts loose on the fan. Once you have removed them take the belt off then unbolt your fan. Works the same when you are tightening the fan bolts back up. You can use this trick on almost any car or truck with a serpentine belt.
Old May 7, 2015 | 07:00 AM
rsc's Avatar
rsc
And give it a sharp slap on the wrench versus a slow, steady pull to break them loose.
Old May 7, 2015 | 08:55 AM
The fan clutch nut is not that tight. Use a fan clutch wrench that you loan free from an auto parts and tap the wrench one tiny time and remover the fan & clutch in 20 seconds.
alphahumdog
26
Aug 6, 2014 08:58 AM
xanzion
Jul 13, 2012 01:22 PM
paulw1029
Jan 30, 2012 10:22 PM
Shale
Jun 7, 2009 09:23 AM
Dennis
Sep 23, 2006 06:01 PM
