Chirp/Squeak from front wheel area
Old Aug 17, 2011 | 06:08 PM
Indyone's Avatar
Default Chirp/Squeak from front wheel area
I'm having a "chirp" sound coming from the front passenger side wheel area. It happens with every revolution of the tire and speeds up and slows down as I accelerate and slow down. I can really hear it while driving in an enclosed area like next to a curb or wall. Applying the brakes doesn't seem to have any affect on it. I plan on taking it to the dealer this Friday but would like to hear some opinions as to what may be causing it. Maybe a wheel bearing or brakes???
Thanks for your help.
Old Aug 17, 2011 | 06:39 PM
Broken Halo's Avatar
How many miles on your truck? Could be brake pad wear sensor.
Old Aug 17, 2011 | 06:44 PM
Indyone's Avatar
It's an 08 with about 22K on it.
Old Aug 17, 2011 | 07:03 PM
Unless you're EXTREMELY hard on your brakes, that wouldn't be it.
Old Aug 17, 2011 | 07:53 PM
Indyone's Avatar
I bought it with 20k miles on it so I haven't had it long. I wouldn't think it's the brakes either but stranger things have happened. We'll see if the dealer can find anything.
Old Aug 17, 2011 | 07:57 PM
It could actually be the brake pad wear sensor if it was bent "in" when istalled @ the factory. Maybe a small rock has nestled between the rotor and the brake pad. I've seen this happen more than a few times. Maybe a wheel bearing starting to go also. I had to have one of mine replaced @ about 25K on Mr. Black.
Old Aug 17, 2011 | 08:45 PM
Indyone's Avatar
Thanks guys. I'll find out Friday and post what I find out.
Old Aug 18, 2011 | 07:33 AM
WannaScoopaDis's Avatar
I am betting its a wheel bearing. I have had one go out that soon on my old TrailBlazer... If thats the case, it's an easy fix!
Old Aug 18, 2011 | 08:50 AM
Widespread Hummer's Avatar
A few months back my pad sensor on the pass side started chirping. I got all the supplies to replace the brakes, took the wheel off and found the pads were fine. The tab was bent in about 1/4" more than the drivers side. I would check it yourself if you can. I wouldnt trust a dealer to tell you if it was bent. As we all know, if there is an opportunity to make money they will take it.
Old Apr 29, 2013 | 06:07 PM
mikebus7's Avatar
Did you ever find out what it was. I am having the same issue right now.
Piranha
21
Apr 2, 2016 08:00 AM
snw4me
Jun 5, 2013 11:29 AM
snw4me
May 31, 2013 10:04 PM
SedonaBoundH3
Apr 11, 2012 02:08 PM
TOYBOX
Jul 28, 2010 04:37 PM
