A/C not blowing through the center vents
Old Aug 27, 2017 | 01:07 PM
daking1959's Avatar
Default A/C not blowing through the center vents
Greetings, my brother has a 05 H2 that the only way it will cool is through the vents at the base of the windshield. It does blow out cold air.
Nothing through the vents above the command center.
any ideas?
dk
Old Aug 28, 2017 | 10:10 AM
LoJac963's Avatar
Blend door, search on here. There's a lot of info on replacing them.
Old Aug 28, 2017 | 04:38 PM
Zombie01's Avatar
YUP, blend doors!
Make sure you have the limits deleted out of the AC / HEATER head unit using a Tech II. Or it could ruin your new just installed actuator motors.
The other common issue is cold air on drivers side and hot air on pass. side.
Old Sep 20, 2017 | 09:20 PM
Dionkraft's Avatar
This issue is the MODE door which diverts the air to the area you select when working properly. That actuator is located just above the gas pedal.
H2_UK
Jul 19, 2018 09:03 PM
Ghost Rider
Mar 15, 2013 05:56 PM
FLCHRIS
Nov 6, 2009 11:04 AM
MPWR99
May 3, 2009 09:42 AM
