Bumper in, need install advice please.
My bumper replacement has arrived. It is very similar to the one pictured below but is for an H3, not a ford.
I need some advice. What do I do first? Torsion bar then install bumper replacement then alignment ~or~ bumper replacement torsion bar then alignment? I would think that it would make more sense to replace the front bumper, then adjust torsion and get it aligned but maybe I am wrong. Will having the bumper on first then adjusting torsion bar create any kind of strain? The thing is heavy, I did not weigh it but those who have it know it is a heavy beast.
Any and all comments/criticisms/advice welcome.
Oh, one thing I will say,I ama bit dissapointed in the look. The pic above shows 2 cross bars on the front middle, mine did not have it.I called and found out why they changed it. I had mine custom made so I can get the Warn Powerplant winch. They told me on the phone that one of the two bars would have to be moved up an inch or two, but when I got it both bars were gone leaving just the top bar going across. I called and after the salesman finally called the shop, they told him that in order to accomodate that winch they removed both vertical bars. Kind of a bummer, as I liked the extra protection but I am still happy.
Rob
Rob
Hey Rob.....Nice looking bumper. Tough Country right?
The thing that seems to make the most sense is Bumper, Crank, Alignment.
Are you cranking it up to return to your starting point or are you gonna go a bit higher with 35's in mind?
If it is the latter, I'd definitely get some Cognito's from Phil to go along with the crank.
Perhaps even some of his new poly bump stops when he starts selling them.
Depending on the weight of that thing and the winch, I wonder if you might not want to look into a set
of T-Bars for an Alpha....The extra spring rate for aV-8might just cancel out that bumper and winch.
(unless you already have an Alpha, I can't remember)
Can't wait to see some pics of that bad boy.
Definitely put the bumper on first. Even with the SAW t-bars, my front end dropped about 3/4" with the bumper installed. I would definitely look at upgrading the torsion bars if I were you.
They fed you some BS on that crossbar. There was one bar on the prototype that they did for Bullydog. I was expecting it as well, but noticed they had removed it from the design when I got mine. Oh well, just leaves more room for lights.
Check all the hardware before you start working on the install. Almost all the bolts they sent me were the wrong length. Easier to run to the hardware store if the front of your truck is still put together. And get a friend or two to help with the install. Two to lift and one to get the bolts started.
I think I listed some more stuff in my last response to you about this. Any other questions, let me know.
I agree with Gunner - especially the pics part!
I will keep you all up to date.
Thanks,
Rob
Rob - you're in Sierra Vista? Geez, I'd offer to help but that's waaayy down there from Phx. That $300 doesn't sound like a bad deal. I paid $200 for the t-bar crank, shock install and alignment and the bumper is more work. It's not something I can do myself, working in a condo parking lot[:@]
Rob - yes I have the Cognito shocks and Sway-A-Way torsion bars. Makes a huge difference. I also have some extended bumpstops on the way.
$300 for the install sounds like a great price. Obviously they haven't seen the size of that bumper.
I opened the accessory box today. Bolts/washers and some other stuff but no instructions. I was hoping for a basic "remove this first, then remove this then install this" type thing but nothing. Wish me luck as I try to figure it out.
I am pretty mechanically inclined and do a lot of stuff myself but after my quick look at the plastic below the chome chrille I did not see what to take off first. I will keep you all posted.
Rob
I am pretty mechanically inclined and do a lot of stuff myself but after my quick look at the plastic below the chome chrille I did not see what to take off first. I will keep you all posted.Rob
cgray11
Oct 7, 2014 06:25 AM
mismatch
Aug 12, 2013 03:35 PM
BlackH3NJC
Feb 16, 2010 03:12 PM
griz7674
Feb 6, 2010 01:55 PM
