Back up Camera
Old Nov 12, 2013 | 11:30 PM
Threedog's Avatar
Default Back up Camera
Any thought on a good back up camera? 05 H2 SUV
Just bought a few days ago. Wiring is in place, fortunately, so it should be plug and play.
It looks like it probably turns on anytime you put the shifter in reverse, is that correct? Anytime we shift, the nav screen goes blank. I assume once the camera is in place, it should be showing the camera view.
Old Nov 13, 2013 | 01:58 AM
fyr145's Avatar
It would depend if you have the factory one or an aftermarket one.
If you completed the wiring, then you should be just about finished. Install the camera unit and connect as directed. Most systems activate when you go into reverse.
I have the factory system so I can provide more info for you if that's the system you have.
You might also do a search here and just type in "backup camera" and see the other threads already discussing this issue for faster information.
Old Nov 16, 2013 | 04:59 PM
accely's Avatar
that sounds correct. I"ve used both cheap and expensive backup cams and i HIGHLY suggest paying more. the cheap ones (10-30$ will go bad very fast). I've used this camera on 2x H2's and it's amazing, high quality image and doesnt crackle or flash alot when you go into reverse, seems like the cheap cameras take alot longer to power on (from the reversing) and display a clear picture. Clarion CC4001U - you can find this around 100 or less, really nice cam.
Old Nov 16, 2013 | 05:08 PM
fyr145's Avatar
I would agree..............you get what you pay for. Don't cut corners for cost, especially if its a safety feature!!!
Old Nov 17, 2013 | 03:47 AM
Threedog's Avatar
I have ordered a camera. It was $25. Haven't received it yet. The one I ordered wasn't CMOS, but CCD. According to what I read, the CCD was supposed to have a better picture. Also, the one I ordered had IR LEDs for night vision, which is what we really needed it for.
We'll see. For $25, if it doesn't work out, no big deal. I can order something else later.
Thanks for the input though.
Aggiedad04
Jun 7, 2018 03:28 PM
champipple
Dec 9, 2012 02:31 PM
TexasNative83
Dec 17, 2011 05:56 PM
bogy
Sep 5, 2006 05:38 AM
bogy
Aug 18, 2006 10:17 PM
