any way to disable the TPM?
Old Mar 28, 2011 | 10:27 AM
loud pipes's Avatar
Default any way to disable the TPM?
I've seen a ton of posts about how bad the TPM is, and I agree. I now have a low pressure idiot light blaring in my face and I can't stand it. I've had all tires at various PSI from 34-44 (running 33"ers). Does anyone know how to "turn off" the TPM, whether that's even possible? I just want to disable the damn thing altogether.
Other than that, love my 06 H3 Lux + Adv! Thanks.
Old Mar 28, 2011 | 12:42 PM
NOPE, you can't disable the system.
Old Mar 28, 2011 | 12:56 PM
You may have a TPMS battery going bad??
The ONLY way to get rid of it is to remove all the TP Monitors next time you have tire work done, drill four holes into a 12-18" piece of 2.5" pipe [threaded at each end] the same size as the TPM stem opening, install the TPMs through each hole (just like each wheel), cap the ends of the pipe using plumbers dope, air up the pipe to 36PSI and drive around with that inside your truck.
Silly, but many people do this?
Old Mar 28, 2011 | 03:36 PM
loud pipes's Avatar
I was afraid of that...thanks for the responses.
Old Mar 28, 2011 | 04:02 PM
08JJ's Avatar
Go somewhere like NTB, they can tell you if the sensor is bad.....all they do is break the bead of the tire and install new one.....the DORMAN part is 48574 and the Schrader part is SV20131...there are a few others around but these are the big names.....about $60 ea with breakdown fixes the problem....may not be worth it to some but definitely worth not seeing lights to me and a much easier fix to do it correctly.
drtom
Apr 21, 2012 02:49 PM
drtom
Apr 20, 2012 10:50 PM
jrs2005
Apr 21, 2008 09:52 AM
geeggee
35
Feb 10, 2008 03:47 PM
AZH3guy
Jan 29, 2007 03:17 AM
