disable automatic door lock function
Old Apr 19, 2008 | 12:44 AM
jrs2005's Avatar
Default disable automatic door lock function
I have a 2005 H2 automatic, the owners manual gives a choice of having the doors lock in gear or with speed. Can you disable that? I never want my doors to lock unless I lock them. The manual talks about it being possible but it seems to be only for the manual trans truck? Anybody know how to disable this annoying feature?
Thanks in advance.
Old Apr 19, 2008 | 03:08 AM
Default RE: disable automatic door lock function
Pretty sure it's in the DIC???
Old Apr 19, 2008 | 11:08 AM
jrs2005's Avatar
Yes it is in the DICbut it only offers 2 choices, in gear and with speed. The factory manual has "take no action" as a choiceand it has the codes to get there, but it doesn't work. I guess the 2005 can't do this. If anyone knows more I'm interested.
Old Apr 19, 2008 | 03:01 PM
dizzy's Avatar
There is a way to disable the automatic door lock feature without using the DIC. You use the turn signal lever and the key. Because I have the manual on my computer I will have to write the information down first then come back to Hummer Forum to type it in.It gives you about 30 seconds to program the new setting or it resets to the default. When I get a chance tonight I will enter the procedure here.
Old Apr 19, 2008 | 09:47 PM
Go Figure???? I had No Idea!!!!
Old Apr 20, 2008 | 12:05 AM
dizzy's Avatar
Here it is. Remember you want MODE 3. First- Ignition off-Pull turn signal lever toward you &hold it there while you perform the next step. Turn key to run than back to lock twice. Then with key in Lock release turn signal lever.The doors will now lock & unlock. Horn will chirp twice and 30 second timer will begin. You are now ready to program the locks. Press the lock side of the power door lock switch once. You will hear 1,2,or 3 chimes.The # of chimes tells you which mode is currently selected. Continue to press the door lock switch untill # of chimes is Three which is NO AUTOMATIC DOOR LOCKING. If you take longer then 30 seconds you will have to start at the beginning. Turn key to RUN to exit programming. Hope this works.
Old Apr 20, 2008 | 02:16 AM
Way to go DIZZ!!!Name:  thumbsup.gif
Old Apr 21, 2008 | 09:52 AM
jrs2005's Avatar
You are right. Thats what the shop manual says to do. Unfortunately it does not give a third chirp. I don't think the 2005 H2 supports this. Books have been wrong before. Oh well. Thanks for all the help.
jrs2005
Nov 26, 2010 08:59 PM
stevbo
Nov 2, 2009 03:08 PM
Nxsov180db
Apr 17, 2008 04:51 AM
Dennis
May 15, 2007 12:54 PM
littlehummerboy
May 10, 2007 08:58 PM
