After changing battery my AC switch not working
Old Sep 23, 2016 | 03:22 PM
Fadishaya's Avatar
Default After changing battery my AC switch not working
Hello
After changing battery in my h3 every thing is working but i cannot switch the air of ac up or dawn to feet or facing.
Also a noise is comming from a black devise (sensor) under the steering wheel
Can somebody tell me whats the name of that device !
Thank you
Old Sep 23, 2016 | 03:28 PM
happythree's Avatar
sensor? or motorized vent? air flow is controlled by computerized motors with rotary feeback sensors to tell the computer where it is. can we say overkill!!
some posts show how to fix/change. gotta search. i saw it long ago??
have no clue why it went when it did??
Old Sep 23, 2016 | 03:41 PM
Fadishaya's Avatar
I really appreciate your quick response
This is the picture just uploaded it in the link
https://postimg.org/image/hxbckbpc5/
Hope its clear to tell me the name
Thanks again
Old Sep 23, 2016 | 03:47 PM
Fadishaya's Avatar
Thumbs up
Thanks again
Old Sep 25, 2016 | 05:52 AM
khaled's Avatar
Post
It is the mode actuator that Controls which vents the air comes out of, ACDelco #1573199 or GM#10397102 .
Attached Thumbnails After changing battery my AC switch not working-mood-actuator.jpg   After changing battery my AC switch not working-mood-actuator-acdelco-1573199.jpg   After changing battery my AC switch not working-mood-actuator-gm-10397102.jpg
Old Sep 26, 2016 | 01:18 AM
Fadishaya's Avatar
Khaled thanks for the best answer, I have already disconnected the mode actuator, COS THEY ARE MAKING A NOISE ( the white circle in the middle is not turning), and at the same time every thing is working fine even the AC is perfect.
But I have here a question what if i kept these disconnected and note that when ever i turn on the H3 only the clock time reset to 12PM while the channels stayed saved.
any suggestion, I believe once the time will work the mode actuator will stop doing the sound.
Old Sep 26, 2016 | 10:51 PM
happythree's Avatar
you might be able to open up the actuator and check the gear assm to see if its out of place .making noise may mean its past the end of range. the noise must be caused by that but im sure has nothing to do with the clock time. sounds like the volts wire to that got opened. look at wiring for help on clock. the stations are in memory i think. the clock runs on radio volts. is that connector/wiring messed up? sounds like it gets opened up with key off?
i think earlier posts on this showed the actuator insides?? dont know where as i have little luck searching.
Old Sep 27, 2016 | 09:56 AM
650Hawk's Avatar
The actuators are easy to replace, and pretty cheap (about $25) on Amazon or eBay. I had the noise/clicking issue with mine...tried messing with them, disassembling, did the reset procedure...still nothing. Finally replaced them; haven't had a problem since. BTW, the actuators have absolutely nothing to do with your clock/radio. Check for a blown fuse?
JensH2
Sep 14, 2025 08:52 AM
HUMdngr
Jun 3, 2013 03:00 PM
spyderbytez
Jan 5, 2013 06:58 PM
garnaout
Jan 17, 2012 01:04 PM
palmxjjsi
Jul 4, 2011 05:26 AM
