Brake Lights Not Working - Fuse or Switch?
Old Feb 4, 2009 | 03:11 AM
spyderbytez's Avatar
Exclamation Brake Lights Not Working - Fuse or Switch?
Hello All,
I need some help getting my brake lights to work. I noticed the other day that none of the three brake lights (left, right & center) will not light up when I press the brake pedal. However, the lamps work when the day lights are on and they still blink with the turn signals. At first I thought it might be a burnt out fuse, but checking the fuse box.. there is no break lamp fuse listed in the manuals. So i'm thinking it may be a switch that is out somewhere. Has anyone else had this problem before? I'm just out of my warranty.. so Ill have to pay for any new repairs - Any help is appreciated!
Thanks!
Old Jan 5, 2013 | 03:22 PM
mountainbiker's Avatar
@spyderbytez
I developed the same exact problem with my '06 H3. Do you recall what caused your problem?
Old Jan 5, 2013 | 06:58 PM
staggs's Avatar
I had the same thing happen to me over the summer. mine was the switch. all I did was take the switch out from behind the peddle, push it in and out a bunch of times to free it up and then shot a little electronics lube on it, haven't had an issue since. I'm assuming they build up a little corrosion over time from moisture from your rain/snow covered shoe.
mine happened immediately after I got it back from gm replacing the radiator so I naturally assumed the bcm was going out, very releaved to discover it was a simple free solution
JensH2
Sep 14, 2025 08:52 AM
badboys
Aug 9, 2022 09:29 AM
dr_tao
Sep 8, 2012 11:30 PM
palmxjjsi
Jul 4, 2011 05:26 AM
rustic4
May 31, 2009 06:10 AM
