2006 Hummer H3 Disable door Chime
Old May 27, 2011 | 05:17 PM
Widespread Hummer's Avatar
Just carry a boom box on your shoulder - problem solved and its super pimp
Old May 28, 2011 | 08:04 AM
bigdawgs2001's Avatar
Smile
Originally Posted by airborne227
I got it...roll the windows down
Yea, I dont mind listening with the windows down, but when you have the doors open and the speakers are exposed outward you get a much better sound..
Old May 28, 2011 | 08:12 AM
drtom's Avatar
Banned
you'd think the 5 door switches would go thru one wire to the bcm,
not so. they used 4 feeds so one switch wont do for all.
i cant find the ding wire and thats the one to switch. next time?
Old May 28, 2011 | 08:19 AM
This same annoyance finally got to me where I had to do something about it. Use a torx driver (I think it was a T15), unscrew the door switch, unplug the 2 wires, and you'll be all set. The whole process takes about 1 min., so it's not that big of a deal. Eventually I'll cut one of the 2 wires going to this switch, wire a single pole, single throw toggle switch in series, mount it under the dash, and be good to go.
This seems most logical as long as it does not throw the message center.?.?.?
Old May 28, 2011 | 10:50 AM
Broken Halo's Avatar
Unless they made a change (which I doubt) to the '10's, the driver door is the only one that activates the chime when the key is in the ignition. That is the only switch you need to worry about when you wire in a toggle.
Not possible. The BCM might be smart, but not smart enough to know at what point along the length of the feed wire that there has been a cut and splice of a second switch.
Old May 28, 2011 | 12:44 PM
drtom's Avatar
Banned
yep,,i checked,,driver door only, so one sw will do.
i think i still want to look at power up sw so i dont need key.
report back ltr!
progress
Old Aug 16, 2015 | 12:35 PM
driverjim1970's Avatar
Default I need help
I would love to know anyway I can disable the damn door chime. I like to listen to the stereo when cleaning the hummer and with the doors open the door chime continues.. This with the ignition key turned to the accessories position.. Any help please????
I have an 06 H3 that has no "ding, ding" for the doors open, key in , or seatbelt warning, and the onstar or phone automated voice sounds muffled the new sound is a high pitched noise it makes no difference running or not and when i turn on the radio the noise is still there. Im thinking its the warning system that is "fried" in some way and ive been trying to see if anyone knows how to disconnect or disable this in any way, I even tried a new head unit but the noise remains and thats what leads me to believe it's the warning system. I would also like to add that this all started about the same time my battery got low one night after listening to the radio and had gotten a jump start. Please, any help would be greatly appreciated. 2006 H3 driverjim1970.jj g mail
gkhogg
May 31, 2022 03:59 PM
classenigma
Jun 1, 2015 12:57 PM
stevbo
Nov 2, 2009 03:08 PM
jrs2005
Apr 21, 2008 09:52 AM
jdrew
Feb 19, 2007 02:36 PM
