06 H3 drivers door
Old Apr 11, 2014 | 03:03 PM
parrip's Avatar
Default 06 H3 drivers door
Does anyone know what the Door Check does? The one in my drivers door seems to be making a grinding noise when opening and closing the door. If has to be replaced do you need to take off the door panel?
thanks in advance,
Paul
Old Apr 11, 2014 | 04:24 PM
wfturner's Avatar
Before you pull anything off, check the detent hold open bar/pin and lubricate that appropriately.
It won't hurt to try and lubricate the top and lower hinges too.
Use the lubrication cans that have the plastic stem for the nozzle.
That can get into places where you want to spray.
On occasion, my doors seem to drag and need this procedure
This is just my opinion, before you try and do a major job.
Good luck
Old Apr 11, 2014 | 06:08 PM
Get yourself some good silicone lubricant and spray all moving contacts.
Old Apr 12, 2014 | 09:17 AM
happythree's Avatar
use whats left in the can for all the door seal rubber. do that in nov and the doors dont stick when its -15! i still use sil grease on the skylite
Old Apr 18, 2014 | 12:56 PM
parrip's Avatar
It didn't seem to help. I may have to take the door pannel off and see what's grinding.
Old Apr 18, 2014 | 02:24 PM
happythree's Avatar
hold open bar/pin ...if you unhook it, its very hard to reconnect.
try everything else, lube,?
ZX10R
Mar 6, 2012 05:45 AM
morad
Nov 24, 2010 04:44 PM
jasonus03
May 29, 2010 09:13 AM
imikeh
Dec 14, 2009 05:10 PM
h2d2
Feb 25, 2007 06:43 AM
