New to Civilian HUMMER
Old Aug 27, 2018 | 10:18 PM
SVTII's Avatar
Default New to Civilian HUMMER
I just test drove a 2006 H2 with 115k on the odometer. This is a Texas vehicle and don’t know the history, but I’ve always been interested in them so I just decided to take a drive to a dealership to check it out.
Now, I’m not new to GM vehicles so I’m familiar with the Vortec engines. This one drove well. Transmission shifted well and there was plenty of power from the stoplight to kicking it into passing gear at 70. There were a few minor issues in the suspension and when i shifted the transaxle into 4-L, there was a slight hesitation and a little jerking for a second or two before is smoothed out.
I did notice rust on areas along the chassis, rock slider welds and body mounts that concerned me. There were bubbles under the paint on the rear quarter panel just above the bumper on the driver side.
Before pulling they trigger on an H2, is there anything i should be aware of other than the obvious mechanical issues? This is a new animal to me and I want to make sure I get the best vehicle for the money.
Thanks in advance!
Old Aug 28, 2018 | 01:58 PM
hummer_on_fumes's Avatar
Read this thread:
https://www.hummerforums.com/forum/hummer-h2-8/most-common-problems-h2s-18186
Old Aug 28, 2018 | 08:35 PM
H2Miami's Avatar
Rust is easy fixed with a product sold in amazon I know is a 3M product but I can remember name now
even my Hummer from Florida (no salt on highways ) was showing patch of rust
My knowledge in the tranfer case options is very limited but Im almost sure the 4L acting the way you described is normal . Remember you shouldn't drive at high speeds in any other setting than 4H . Make sure to know the 4wd settings before you play with it . A bad selection may damage the TC
the link.provided by HOF is full of info
Most H2 here are way over 115k with minor issues
Old Aug 29, 2018 | 09:34 AM
Also read the owners manual (you can even download it from the GM website if needed) and be aware of how to correctly operate the 4WD controls. The H2 if full time AWD and the controls look the same as on the regular trucks but must be used a little different.
Old Aug 31, 2018 | 09:40 AM
madmayo's Avatar
The rust on the rear quarter is pretty common. It is caused by that rubber trim they use to fill the gap between the bumper and body. As the chassis shifts with the body it rubs the paint off and then you get the rust. I keep the flat part of the body where the rubber meets coated in grease and it has really helped any further damage from the salt and brine my truck sees. I also get it oiled every fall.If you let it go it will eventually travel up the side of the body and rot around the gas cap area. Very unsightly.
i have owned a few gm trucks from this era. I must say the h2's are pretty rock solid and the best gm product i have owned from the 2000's
Things to look for:
water markings around sunvisors- usually clogged drain tubes or marker lights- check rear markers as well
door panels - look for cracks around handles and map pockets- hard to find to replace and $$$
rear license plate tray- crappy engineering held in by 6 plastic studs- usually broken. Ive had to fix mine several times
mirrors- make sure they function is intended- especially 03-05- discontinued
exhaust mainfold- bolts- like all LQ's they like to snap the heads off- passenger manifold likes to crack
Also check if they have mounted a transmission by pass cooler. The trans fluid runs through the rad and if the rad lets go it will toast the trans.
Be patient and find the best truck you can afford
Old Aug 31, 2018 | 10:51 AM
SVTII's Avatar
Madmayo, thanks for the reply. Those are some great points.
Ive found a few here in Texas but I’m about to relocate to the Tampa area of Florida. I’ve done searches in that area and there seems to be a lot more to chose from there. I am going to be patient and try to find the right one. Thanks again!
Old Sep 1, 2018 | 01:10 PM
H2Miami's Avatar
@madmayo . Good points .
Mostly the transmission aftermarket cooler mod . Will save a big headache
The transmission runs cold even while towing 4000 pounds @ 190 max in a 100° weather
Old Sep 1, 2018 | 08:32 PM
hmer's Avatar
welcome to the forums . i got my 04 H2 in houston than later moved down to TAMPA you can find some good deals around the tampa bay area but if i were you ill try to pick one up in texas , in florida lots of h2 owners had their H2 near or in salt water and do not have any underbody treatment at all and that my friend can bring some problems to you the new owner down the line . another thing to look for is to make sure you check all the lights up in the roof H2s leack water that goes in through the lights , inside the truck check the headliner if it looks like it has any stains near the front windshield its s sign that the previews owner did not took care of that and you may be able to use that at the dealer and get a few $$$ off the price , in my case the dealer took 2500$ off the price just cause of that , in tampa you get LOTS OF RAINN so you will deal with water alot ..... again welcome to the forums and hope you enjoy tampa ,florida can be fun at times .
Old Sep 2, 2018 | 04:20 PM
madmayo's Avatar
One thing i forgot to mention. Was that when i was looking i stayed away from the air suspension and found one that had coils. I know that they ride better but these trucks are old and the air suspension can become an pain in the a$$.
Old Sep 2, 2018 | 06:23 PM
SVTII's Avatar
I did notice that and I was wondering if that was a factory option. I figured I’d stay away from that and If I wanted one later, I’d install an aftermarket system.
twynbyz
Jun 24, 2018 05:51 PM
nyh2new
Sep 27, 2017 04:06 PM
Sharpshooter
Jun 2, 2017 11:10 AM
jts
Sep 24, 2009 09:42 PM
JohnsHummer
Sep 26, 2008 11:18 PM
