Keyfob
Old Mar 20, 2020 | 06:24 PM
4XGirl's Avatar
Default Keyfob
My key fobs both stopped working a few months back. Besides replacing batteries would they need to be reprogrammed all of a sudden?
Old Mar 20, 2020 | 06:26 PM
i have seen people have the same issue with the aftermarket amazon/ ebay ones. seem to work a few months then both just die.
Old Mar 20, 2020 | 06:30 PM
4XGirl's Avatar
Mine are the originals, but weird that they both stopped working at the same time and not sure why they would need reprogrammed. Just wondered what all of you thought. There is a GM dealer not too far away so maybe I'll just stop by there sometime.
Old Mar 20, 2020 | 07:41 PM
No need to reprogram! Start by checking battery resting voltage.
Old May 25, 2020 | 11:05 AM
QuandAns42's Avatar
There should be no need to reprogram the original fobs as it doesn't 'wear off' or anything of that sort. However, they may need to be replaced and the new fobs would need to be reprogrammed. If you've already changed the batteries, you might try to give the circuit board a gentle cleaning with ispropyl alcohol to remove any debris or residue which inevitably accumulates over time. If they still don't work you may need to try a replacement. There are plenty of sites selling replacement fobs but it is important to buy from a knowledgeable seller. You'll need to get a fob with the correct FCC ID and chipset for your VIN.
Old May 25, 2020 | 11:07 PM
hmer's Avatar
man i got a set of 2 for 19.99 on of amazon 5 years ago the only thing that happened really fast was that the lock symbol fade it away but they both work really good . my guess is it depends what vendor you got them from . here is the link for a set of 2 https://amzn.to/2ZBF6he
Old May 26, 2020 | 12:22 PM
It would be helpful to know what Hummer you are asking questions about. This should be asked in the vehicle specific section.... if it is an H3, it goes in the H3 section. Crazy how that works.
upnorth
Aug 13, 2018 09:36 AM
Zero83
Oct 3, 2016 12:05 PM
Gdraft
Dec 29, 2015 03:46 PM
CharlieDeltaJuliet
Jan 1, 2014 11:35 AM
RaYoSeKiZ
22
Dec 20, 2013 08:27 AM
