Torsion Bar Removal Help
Old Jun 11, 2023 | 08:36 AM
H3T Stick's Avatar
Default Torsion Bar Removal Help
Need to replace the bushings on the lower control arm (LCA)
How does one remove a stuck torsion bar on an H3/H3T?
The torsion key and bolt in the middle of the vehicle is out.
The torsion key has been removed.
The passenger side (not tried the drivers side) is stuck in the LCA.
Tried PB Blaster, some mild heat, and of course pulling and wiggling the bar.
Tried a pair of vice grips with a rag and clamped that onto the bar and then tapped the vice grips with a hammer.
Did I miss something?
Since the back of the torsion bar has flanged out a bit, thinking of making a bracket and some kind of pull to pull the torsion bar out.
Any other ideas???
TIA.
Old Jun 11, 2023 | 03:43 PM
Old Jun 11, 2023 | 04:01 PM
H3T Stick's Avatar
Thx your for the photos. Those and others were helpful in getting me where I am now. The large bolt and torsion key have been removed. The LCA is dangling free (Shocks are moved, wheel hub assembly is removed, etc.).
The problem is that the torsion bar will not come out of the lower control arm.
AFAIK, after removing the large bolt and torsion key that is under the passenger side, the torsion tube should just pull out of the LCA.
However, my torsion tube seems to be stuck?!?!?!
Any tricks or ideas to get the torsion bar out??
Old Jun 11, 2023 | 04:17 PM
Use an air hammer with a blunt bit and hit/vibrate the bottom & sides of t-bar at lca.
Old Jun 11, 2023 | 04:52 PM
Obviously rust welded to the control arm. "Go big or go home" & "Act like you own it". Fight the battle to win!
Lord_Vien
Sep 19, 2022 01:25 PM
KevinA
Mar 20, 2022 02:41 PM
Datboy_B
May 31, 2014 10:51 PM
Indy
Mar 7, 2011 08:33 AM
HummerGuy
May 10, 2007 02:22 PM
