Removing torsion bars to access catalytic converter
Old Mar 13, 2022 | 12:31 AM
KevinA's Avatar
Default Removing torsion bars to access catalytic converter
How much ouble is it to actually remove the torsion bar competely.. It appears it needs to be done in order to get the exhaust pipe and cat out. How difficult is it to actually get the torsion bar back in once completed. Is the process just removing the torsion key, then sliding the bar out. The replacing it, just replace the torsion bar in the key and then fastening down the key? Do you actually need a torsion key tool/c clamp thing? I read something about that.
Old Mar 14, 2022 | 09:41 AM
You do NOT need to remove a torsion bar to do exhaust work.
Old Mar 20, 2022 | 02:41 PM
KevinA's Avatar
If you want to remove the mid pipe and catalytic converter I’m pretty sure you do because you can’t move the pipe out forward because the torsion bar prevents it and you can move it rearward out because the car doesn’t fit through the brackets and transfer case
anyway. Easy job.
SurvivalFreak
May 11, 2012 10:51 AM
busa944
Jul 18, 2011 09:47 PM
Indy
Mar 7, 2011 08:33 AM
JPSH3
Feb 18, 2011 01:09 PM
bmbenear
Nov 20, 2008 10:20 PM
